To achieve a P&L style look I am using conditional formatting to change the background colour of certain cells in a matrix. It is working nicely except where some profit centres don’t have income (ie. the value shows as blank), the conditional background colour isn’t applied.
See the below image. The first, second and last profit centres have income and hence the line turns green. However the third, fourth and fifth profit centres don’t have income and the conditional formatting isnt applied.
Is there a workaround for this, preferably that won’t kill my performance?
A sample PBIX would be a great help so we can see your formula in order to help.
How are you calculating the background colour, via DAX and pointing it to that measure? If you do it that way, you can make use of the ISBLANK function, that I should imagine will help your issues.
Thanks @jamie.bryan for taking the time to respond.
I’ve mocked up an example of how this works. Note that I have a single measure to define the background colour referring to the row header, not the measure value as that is irrelevant. This makes it really easy to both apply to many reports and also tweak (ie. change a shade of grey) and automatically have every report update regardless of what measure they’re using (ie. ignoring whether the report is on MONTH, YTD etc - only the report level matters).
I use ISBLANK a lot but am unsure how to incorporate it into this example given it isn’t referencing a measure, but the header row.
In the example provide both the Total Income and Total Expenses rows should be fully grey but where there aren’t values, they are white.
Apologies I didn’t see the matrix part of your query. That’s a bit beyond me I’m afraid since it’s not looking at the actual values. Hopefully someone can jump in to help!
