Sometime ago (more than I thought anyway) I created a matrix with conditional font color formatting. Can’t find though the rule on which color is set as rules mask contains no info. Formating though works when filtering. I looked under Cell elements as well with no luck.
I’m I missing something here? Would definitely appreciate your help.
Thank you @Dharma but I already checked that.
Even though conditional formatting is on for ‘Food Cost old’ under Cell ellements, no Rules/Gradient/Field value is applied. As said, font formatting is working but I can’t find where the rule is coming from.
I suggest looking in your model for a DAX measure called TextColour. It’ll most likely have an IF statement for the column and colour codes/words for the results.
