Hi
I’ve looked at similar threads but can’t see what I’m looking for.
Ok. I have a column chart with conditional formatting on the bars for different states (groupings). All well and good.
What is NOT working for me is conditional format of the labels. Basically when NO year is selected I don’t want the labels to show (ie white). When a year is selected, OK.
Now the chart has %age labels and when no year is selected, the measure shows more than 100% because it’s the sum of the same score for all years. ie it shows 300% or 256% or whatever. I don’t want that, so I thought conditional formatting using saying "if greater than 0, “white” if less than or equal to 1 black. But it ain’t working for me.
Sorry the image with the colors is fine… I want the labels because a year is selected and the color coding shows the banding. But the top one… ie no color… I don’t want the labels because that’s all years and the %age is meaningless.
Hello @Ericadyson, just following up if the response from @Heather help you solve your inquiry?
We’ve noticed that no response has been received from you since November 14. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi Heather… didn’t see your reply until EDNA sent me a trigger reminder. So thanks. Actually it’s the other way around… but yes, that’s great. Thanks so much. I actually had a version where no chart showed if no years were selected and then they appeared with the correct formatting for the bars depending on the values. But this is also good. Mega thanks. A simple one, but for lesser mortals, help is always needed!
