See attached my excel spreadsheet for problem and desired solution:
I want to concatenate W1, W2 etc onto the date column header. I want to keep the other column headers without any concatenation:
Below is the desired solution screenshot. I want to concatenate the cell into the header if it starts with Wk.
I know this is very awkward but I am not able to change the spreadsheet.
BrianJ
2
@izzleee ,
Once you’ve got the Problem table imported into Power BI, try dropping this into a new blank query:
let
Source = Problem,
#"Promoted Headers" = Table.PromoteHeaders(Source, [PromoteAllScalars=true]),
#"Transposed Table" = Table.Transpose(#"Promoted Headers"),
#"Removed Columns" = Table.RemoveColumns(#"Transposed Table",{"Column1", "Column2"}),
#"Replaced Value" = Table.ReplaceValue(#"Removed Columns",null,"""""",Replacer.ReplaceValue,{"Column4"}),
#"Added Custom" = Table.AddColumn(#"Replaced Value", "Custom", each if Text.StartsWith( [Column4], "Wk" ) then Date.ToText( [Column3] ) & " - " & [Column4] else [Column3]),
#"Removed Columns1" = Table.RemoveColumns(#"Added Custom",{"Column3", "Column4"}),
#"Reordered Columns" = Table.ReorderColumns(#"Removed Columns1",{"Custom", "Column5", "Column6"}),
#"Transposed Table1" = Table.Transpose(#"Reordered Columns"),
#"Promoted Headers1" = Table.PromoteHeaders(#"Transposed Table1", [PromoteAllScalars=true])
in
The key steps are transposing the table and then adding this custom M code to do the conditional concatenation:
I hope this is helpful. Full solution file attached.
– Brian
eDNA Forum – Concatenated Header PQ Solution.pbix (27.1 KB)
Thanks Brian this is very helpful as always.
