Is there a way, technique or best practice, to prevent a report from calculate until certain criteria are fullfilled. I have a request for a very detailed purchase order report who is only of interest after selecting a specific purchase order. So is there a way to condition a report only to calculate if number of selected purchase order is one?
Thanks in advance
I’m not aware of any way to do this automatically, but there are some settings where you can control this manually. Go to the Options menu, and select Query Reduction. From there, you can toggle the two settings highlighted, prevent filters and slicers from recalculating until you manually hit the Apply button:
