@Timmay Yup, the idea is simple, don’t invoke Context Transition on a table that contains duplicates ( Either you know that it contains duplicates or there is a possibility it might contain duplicates ) and by design Fact table will generally contain duplicates unless you have a primary key such as an Order ID which is a bad thing in Tabular models, so always initiate Context Transition on a dimension table and let the relationships do the rest of the work.
I finally got a chance to try this on my live dataset & unfortunately I’m getting an unexpected result. Sorry I can’t share the pbi file (company data). Any idea why it could be happening? @AntrikshSharma
HI @Timmay. You’re posting to a solved thread, so it’s likely that your post will not reach forum members who most often only search for un solved threads; please create a new thread for a new question with a sample PBIX and marked-up screenshot of the visual that’s the issue, noting which rows specifically are incorrect. Also, by calling-out a particular member, you’re encouraging other forum members to not review your post; please refrain from asking for help from a specific member.
that’s fine, I got the answer I was asking for but it turns out I was asking the wrong question in the first place. The CAGR I calculated wasn’t a CAGR at all, the formula is different but I worked it out either way.
