I would like to request help with the final calculation ( Cal 2) which is division 2 values Total holidays and Cal1 ( Total Holiday/ Avg). I need to achieve results like this in the column marked red.
So far I have this in PBI file (below) but the last column doesn’t show the correct values for specific locations ( like in the screenshot from excel )
The file with the expected outcome is already uploaded at the bottom of the previous post and I hope all is acceptable there.
Please find it below as well.
Just following up if the response above helps you solve your inquiry.
If it did, please mark his answer as the SOLUTION.
We’ve noticed that no response was received from you on the post above. If there won’t be any activity in the next few days, we’ll tag this post as Solved.
Due to inactivity, a response on this post has been tagged as “Solution”.
