I have created a dashboard to help us keep track of form completion but I am having some issues.
What I have is a dashboard with 2 tabs. The first tab is intended to provide an overview, and in the context of the real data, it includes feedback to student, amongst other things. The second tab, is supposed to provide an over view of form “count” data.
Essentially what I am aiming for in the second tab is a view where a user can select a rotation, or a site, or a student, and it will display how many forms have been completed based on the selection, as well as a total form completion regardless of rotation selection.
Currently, when the rotation slicer is multi-selected as below, the matrix table visual displays duplicate values across two rows for the same ID, where “Completed” forms across Rotation 2 first half and Rotation 2 second half have different “Expected” values. There may be a better way to display this information than the matrix, but I can’t get it working properly to test out alternative options. I initially had the rotation slicer as single select, as it stopped the duplication of data in the top (4 week) table.
The Response IDs are they the same ID in each table, and does this also correlate to anything else, such as rotation etc?
It hink its happening because Response ID is not a dimension, it can be shown each time it is in the Fact table if you are using the field from something other than a Dim table where it is unique.
Is it possible to have the Response ID as a Dim in the Stat Schema and flattened to include attributes that are linked to the Response ID to avoid snowflaking if possible.
We’ve noticed that no response was received from you on the post above.
Just following up if you still require assistance to solve your inquiry.
If yes, can you let us know where you’re stuck and what additional assistance you need?
Thanks Kylie for your response. That is something I have never considered…I used the response ID as I assumed they would be unique across tables…but I have not actually checked. But no, the response ID is not linked to anything else. I assume there might be some disconnect somewhere in my model, but I hit a brick wall trying to work out where that might be.
I will give your suggestion a shot tomorrow and let you know how I get on.
Due to inactivity, we’d like to conclude that you no longer require assistance to solve your inquiry.
