Hi
I need a PQ solution for the following - I have tried several approaches but none of them work.
All I need to do is combine tables in the Current Workbookstarting where the table name starts with “t_City”.
I need it to be in the most memory-efficient manner possible
Thank You
Allister
Combine.xlsx (14.7 KB)
Hi @AllisterB,
Give this a go.
let
Source = Excel.CurrentWorkbook(),
FilterRows = Table.SelectRows(Source, each Text.StartsWith([Name], "t_City"))[[Content]],
ExpandContent = Table.ExpandTableColumn(FilterRows, "Content", {"Name", "Age", "Value"}, {"Name", "Age", "Value"})
in
ExpandContent
Here’s your sample. Combine.xlsx (108.2 KB)
I hope this is helpful
Hi
Thank You so much
How do I include the Source Table Name in a column?
Allister
Hi @AllisterB,
In future try to avoid this type of re-iteration of your question and supply a mockup of the desired results - thank you!
In the FilterRows step I only kept the [Content] column, remove that selection and you’ll get the table name as well.
Updated file. Combine.xlsx (116.3 KB)
