Quick question.
I have a number of excel files that I am looking to bring into power query using the ‘combine’ button.
these source files have changed in format slightly over the years and I was wondering does the combine function use header names to combine the data from individual files? or does it use column index?
thanks,
Matt
Hi Mks68
from when i’ve used Power Query (addin in excel) i have used a custom functions that works great for combining tables that are similar in the same format. I’ve also had to make sure the columns fields in both table 1 and 2 are the exact same and have no blank spaces.
this youtube link shows someone appending 3 tables you will see there no spaces in all column field names.
and the column names are the exact same in all 3 tables
