Is it possible to collapse the various “main” categories that are in the P&L statement? Revenue is the sum of three categories. But it would be nice if you can collapse revenue to still show the total and not all categories. The same for expenses as it’s a long list.
Thanks!
Financial Reporting In Power BI.pbix (940.7 KB)
If you mean hide the items that make up revenue, then you could untick them in the visual filter, just check the other measures are not dependant on them being visible
Hello @UserNoName
Thank you
Hi @UserNoName
We’ve noticed that no response was received from you on the post above.
Just following up if you still require assistance to solve your inquiry.
Hi @UserNoName
Due to inactivity, we’d like to conclude that you no longer require assistance to solve your inquiry.
