Team EDNA and friends, would request for an assistance in trying to find the % difference between each periods of the cohorts.
I tried to use the exact steps outlined by Sam in the learning summit - Cohort Analysis Introduction, but the results are not working in productin the % difference…
Here’s how it looks
The dax used to calculate retention and unique customers as follows
Retention %
Unique Customers
Retention Periods
here’s how the data looks when i pull in the base files - retention periods and unique customers along with join month
regards
Hi @sanappi09, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
- Use the forum search to discover if your query has been asked before by another member.
- When posting a topic with formula make sure that it is correctly formatted to preformated text </>.
- Use the proper category that best describes your topic
- Provide as much context to a question as possible.
- Include demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
As suggested above please add a PBIX file for questions like this. These can be very complex and also very difficult to answer without seeing everything that could be going on in your report and model.
Hi , we’ve noticed that no response has been received from you since the 7th of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
