Thanks @ankit!
I mentioned Combo Chart and I did try already Line and Clustered Column chart:
In Excel I can bring in the percentages relatively freely to the intended postion (data label can be independent from the value fo the line hight), but I don’t know how to achieve that in Power BI.
My current solution is a separate visual below which I use for the percentages. With a fixed number of items it would be easy to align the visuals perfectly, but for changing number of items it’s not ideal.
-turn off in the below visual Title, X-axis and Y-axis, turn on Data labels
-turn off in the below visual under Advanced options “Responsive”
=> that will allow you to reduce the hight of the visual so that it is very slim (s. picture above)
If you have a fixed number of items it is very easy to align the two visuals perfectly.
If you have a changing number of items the alignment is can not be done perfectly (s. picture above), but in most cases it will be good enough.
