When I go to the column that I want sorted, I select the column and then click on the sort by column icon and select the new calculated column “Departmentid”. I immediately get a circular reference error. What am I missing.?
HI @lomorris. This bit me as well when preparing a recent challenge submission (perhaps [Dept.] is calculated itself so [DepartmentID] is a calculation of a calculation? If so, calculate both the field and the sort off the same base field).
Hope this helps, or please post a PBIX for the forum members to investigate further.
This is an interesting issue, I have always solved this type of problem in Power Query, instead of creating a calculated column with DAX, I do it with a custom column before the table is loaded to the model.
I had never even considered doing it as a calculated column.
Yet another example of multiple ways to do things in Power BI (just as in Excel)
@lomorris@Greg Alternatively, you can do it in DAX but you have to make it a table using SUMMARIZE (not SUMMARIZECOLUMNS), with the switch statement, then you can sort it by that column. You would then have created a dimension table, and you can simply create a relationship back to the main table.
For example, this is using the data set for challenge #9:
Test = SUMMARIZE(filter(Trading,Trading[Haulage Currency]<>blank()),Trading[Haulage Currency],"ID",switch(Trading[Haulage Currency],
"(€) - Euro",1,
"(£) - Pound Sterling",2,
"($) - US Dollar",3,4))
And then of course utilize this table in your axis and slicers to have the right sort order.
