Hello Fellow Power BI Users -
Good morning and hoping you can help me.
Exporting to excel from Power BI:
- Currently Power BI provides a default file name as "data.csv’ when using Export to Excel.
- Is there any way to override the file name and substitute it with a value of measure ?
Use case: - Have a measure in the application which has concatenated values of selected Product, Location and Time. An example of such measure value would be: “Product63-FL-2018Q2”
Can the default file name be changed to “Product63-FL-2018Q2”.csv instead of “data.csv” ?
Thanking you in advance.
Best regards…Adi
