Hi
I have a question About Drill Through. is it Possible to change The text of Drill Through? I want To change it to Right Click to see the Details. I know It is possible to use button, But I need to change this text. I need a meaningful text for General user instead of “Right Click to Drill Through”
I don’t think you can change the text but you could create a drillthrough button
Create a drillthrough button in Power BI - Power BI | Microsoft Docs
Hi @HosseinVossoughi, have you tried the suggestion above?
No , I think I need a programming Soloution. IT’S not supported in Power BI Desktop.
Hi @HosseinVossoughi, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
