I am looking for advice on how to go about changing my model to a Star Schema and still be able to filter on FY23,FY24 and FY25? I am asking how can I obtain the same results as my attached PBI by changing some aspect of the model? Currently I am using two disconnected tables with a many to many relationship to achieve an allocation qty and $ amount. I anticipate I will have more items than the three presented here and most likely I would have three separate FY prices to allocate by. Any advice on how to achieve the Star Schema and maintain the accurate result by year is what I am hoping to achieve, without separate measures for each item,
The way I typically handle these sorts of granularity mismatches is to allocate down to the day level in Power Query, join in a compliant star schema, and an aggregate up to the appropriate level using simple aggregate DAX measures.
I did a webinar walking through step-by-step how to implement this approach last Fall. You can find it on the new platform at:
Thank you very much for your reply and pointing me in the right direction. I will watch the seminar now and reply again. I really appreciate how you have always been such a great and prompt resource!
Hi Brian:
That video is great for addressing granularity! My question is how can I make this model a Star Schema and product the same measure results while using a FY slicer? Everything on this particular report is only expressed on an annual basis, so granularity is annual only.
In other words how can I possibly change my model to Star Schema and not to have the many to many relationships between the allocation and price scenario tables. Since the base figures do not change from year to year (just the allocation percent and pricing by year).
