When working with any data, what is the better option?
Change the type within the power query editor?
Or to change it from Power BI settings?
Hi @MGadAllah … I always lean toward the most accurate data model possible, so do all I can in PQ first. Then, and only then, I’ll use the format box to adjust the display value as desired. Hope this helps. Greg
Thanks a lot, @Greg for your reply.
I will follow your advise.
