Change column type if column header is number (from text)
Some column headers are numbers eg 1, 24, 6798… There is an unknown number of these columns but there are also text columns eg “Filename”, “Location” etc. How can I transform column types which are numbers to type number?
I have tried different ways to output a boolean by testing the header text:
All errors prevent the if function from executing. So I added a try otherwise function and it had an error Record to Value or something. Do you know how I can test each column for boolean value
i.e Can the header be converted to a number? If yes type number else type text
See attached PBIX model and transform query:
sample_dynamic_cols.pbix (19.4 KB)
let
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WKkktLlHSUQKijNScnHwgXZxZBCSNTEGEGZCwVIrViQYpKEhNhKhEoNhYAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [No = _t, Soup = _t, #"For " = _t, You = _t, #"1" = _t, #"2" = _t, #"3" = _t]),
    // type change to be dependent whether column headers can convert to number
    TODOconst = "2",
    // example of Bool from try working ok
    TODOtester = try Number.From(TODOconst) > 0 otherwise false,
    // @TODO LOGICAL TRY Number.From or Value.Is
    types = Table.TransformColumnTypes(
        Source, List.Transform(
            Table.ColumnNames(Source),
            // Now bool doesn't work within if statement?
            each if try Number.From(_) > -1 then {_, type number}
            else {_, type text}
    types2 = Table.TransformColumnTypes(
            each if Number.From(_) then {_, type number}
            else error {_, type text}
in
    types2
Hi @izzleee,
Good question! This is a fun one, paste this into a new blank query.
let
    ColNames = Table.ColumnNames(Source),
    ChType = Table.TransformColumnTypes( Source,
        List.Zip(
                ColNames,
                List.Transform( ColNames, each Value.Type(Value.FromText(_)))
in
    ChType
I hope this is helpful
