Change column order of a matrix
Hello all,
I have a very simple matrix with one row, one column and two measures.
What I want is shown in the image.
I appreciate the help you can give me.
Thank you
Hi @JoaoMonteiro,
AFAIK you can only achieve that if you create separate measures, so External Qty, External Amount and so on, with a limited number of dimension values it’s doable (although not desirable).
Maybe Calculation Groups will allow this - I don’t know @MudassirAli your 2 cents, please…
Hi @Melissa,
I’ve also thought about the possibility of implementing calculation groups but I couldn’t get results.
I also thought of creating a calculated table with the sole purpose of feeding this matrix.
@JoaoMonteiro ,
Don’t know if solving this with custom visuals is helpful to you or not, but just FYI - in Zebra BI tables you can reorder matrix columns just by dragging and dropping. I used the Zebra BI Tables and Zebra BI Charts visuals extensively in my Data Challenge 16 entry and think they’re awesome.
Hi @BrianJ
I’m using PBI Report Server and I’m only allow to use customer visuals.
But thanks for your heads up.
Regards
JM
@JoaoMonteiro ,
Yeah, I figured that might be the case. I would guess that a majority of workplaces don’t allow custom visuals, but it would be interesting to find out.
Hi @JoaoMonteiro , did the response provided the users above help you solve your query?
Hi @JoaoMonteiro, we’ve noticed that no response has been received from you since October 16.
Hi @JoaoMonteiro, due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, please create a new thread.
