@mspanic
Please assist. The row Cash flow imbalance should be 0 as indicated in the screenshot, below.
I am not getting a 0. Cash flow imbalance Is made up of calculations/formulas as seen in the Excel/Sheet file Column K, https://docs.google.com/spreadsheets/d/1ubo9TAz2zzCpKbfO5SFBMjFLgjFtUxhY/edit?usp=sharing&ouid=104129043494164133703&rtpof=true&sd=true
To get the formula click in column K on the value:
PBIX: https://drive.google.com/file/d/1-wHE0e50nSM9-wSq4dTxStDX58APO_MI/view?usp=sharing
I am also getting a repeat of the amount 201256612.25, I don’t know why. Some figures tend to differ when i work connected to the Live source on the Server as opposed to the downloaded version for Desktop
mspanic
2
@Yrstruly ,
For both Excel and PBIX - Access is denied.
So my advice is - use similar logic as you did at:
Regarding different figures - Live source vs downloaded version - it usually happens when figures changes (after downloaded version refresh).
Good luck.
