Hello All,
Does anyone have a solution to cascade Waterfalls the same way as shown below , I thought about using R for doing this , basically each bars represent categories : R
Red bar are Targeted values
Green Bar are Actuals values
Doted gold bar are actuals values with a risk factor applied.
I can provide underlying table if anyone could help me get the same look and feel into power BI.
Hi @johannphill, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
When posting a topic with formula make sure that it is correctly formatted to preformated text </>.
Include demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
Hi @johannphill, due to the length by which this post has been active without response, we are tagging it as Solved. For further questions related to this post, please make a new thread for better visibility. Thanks!
