I am trying to filter a slicer based on the selected value of the Shape Map. Is that possible? I understand that we can’t use a measure in a slicer, so I was wondering if anyone come across the same issue and found a workaround? Potentially a disconnected table? Not sure…
I don’t think this will work on a standard slicer, but any time you can harvest a selected value(s) (which you can do with a shape map), you can build out the DAX in combination with the filter pane to mimic that slicer action using a disconnected table slicer.
