It happened a lot that I can not add the item I want to the secondary axis.
How do you solve this issue?
Or how do you trick PowerBI in that case?
A gentle reminder, please.
Hi @MGadAllah.
Unfortunately your original post does not explain things well, so I’m not surprised responses have remained elusive.
To help the forum members further analyze your current state and visualize your issue, could you please provide as many as you can of:
- Your work-in-progress PBIX file, using sanitized data if necessary
- here’s @BrianJ’s YouTube video on how to anonymize data in a Power BI file: https://www.youtube.com/watch?v=VmWD7Ayw_NI
- Your dataset as an Excel file (again, sanitized if necessary)
- A detailed mock-up (marked-up screenshot of the visual in question or Excel file) showing your desired outcome.
Also, if you provide DAX or Power Query code in your post, please format it using the built-in formatter.
P.S.: At the risk of exposing my background (and age) too much (and apologies in advance to all), when you said “… how do you trick Power BI…” I immediately thought, “… AFAIK, there’s no [Kobayashi Maru] in Power BI …”
Hi @MGadAllah we noticed you didn’t provide a PBIX file. Providing one will help users and experts find a solution to your inquiry faster and better.
A clear explanation of the problem you are experiencing
A mockup of the results you want to achieve
Your current work-in-progress PBIX file
Your underlying data file (to allow us to go into Power Query if necessary to transform your data and/or data model – often DAX questions really end up being data modeling solutions)
Hi @MGadAllah we noticed that you have not responded to our request last Jan 5.
We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
