Can a developer with power bi pro license publish a data set which is 3gb into premium capacity workspace?
Can a developer with power bi pro license publish a data set which is 3gb( >1 Gb ) into Dedicated premium capacity workspace? or does he need premium license (ppu) to publish the 3 gb dataset to a premium capacity workspace?
I don’t believe that user will even see the workspace as one he can publish to.
Hi @prasad1 - I replied on earlier post also. If that developer have any role greater than viewer role on workspace then yes can publish the file of 3 GB on premium capacity.
Ankit J
Not if they’re only a Pro user, though.
