Calculating Sum of savings not total
Can someone help me with this Dax? I am trying to calculate the total saving of the individual fabrics in this table and not the total but I can’t understand how I get that.
The table is showing me the correct information for example in this product I cut 3 fabrics
401641
406423
411266
I haven’t cut 401641, yet, so there is blank data, but for the other two, there is, and I can see that compared to my Total BOM qty SQM my new total proportional area per part sqm is improved thus, I saved money as shown in the table.
What I want to do in the card is have the total saved on this product, so it should be the total of 12.59 + 31.25 = 43.84 saved on this kit so far, not 2.18k as shown.
I want the total of the 2 numbers in the red box and not the total in bold basically.
Plataine Vs Strata 2.pbix (815.9 KB)
Thanks, and appreciate the support
Dan
Hello @Krays23,
In order to achieve the results based on the scenario that you’ve provided. Below is the DAX measure alongwith the screenshot of the final results provided for the reference -
Total Cost Saving - Totals =
SUMX(
    ADDCOLUMNS(
        SUMMARIZE(
            'Plataine Reports' ,
            Fabrics[Current SAP Raw Material Number] ,
            Products[Current SAP MM Part Number] ,
            Products[Old SAP MM Part Number] ) ,
        "@Totals" ,
        [Total Cost Saving] ) ,
    [@Totals] )
I’m also attaching the working of the PBIX file as well as providing a link of the post pertaining to the topic - “How to Fix Incorrect Totals” for the reference purposes.
Thanks and Warm Regards,
Harsh
Plataine Vs Strata 2 - Harsh.pbix (811.3 KB)
EDIT: In case, you want to round up the numbers upto 2 decimals places then wrap the measure alongwith the “ROUNDUP()” function.
ROUNDUP(
    SUMX(
        ADDCOLUMNS(
            SUMMARIZE(
            "@Totals" ,
        [@Totals] ) ,
    2 )
Thank you so much @Harsh
So annoying as you guys make it look simple! and I always think why didn’t I think like that.
So here you just created a virtual table and then SUMX the table ?
Dan
Hello @Krays23,
You’re Welcome!!! :slightly_smiling_face:
I’m glad that I was able to assist you with your query.
Yes, a virtual table has been created with the correct totals and then summing them by wrapping it inside the “SUMX()” function.
Harsh
@Harsh
How do I adapt your DAX to show results on all selected dates? I know I need to use AllSELECTED but I can’t figure out where to place it. Basically, I need the results to show parts cut and savings on that day that I select from the date filter.
I have changed the matrix columns to values from filter tables as opposed to fact tables before, and now I see all parts cut on all dates, and the filter isn’t working.
Grrrr
Plataine Vs Strata 3.pbix (1.2 MB)
Total Cost Savings =
ROUNDUP(
    SUMX(
        ADDCOLUMNS(
            SUMMARIZE(
                'Fabrics From BOM'[Current SAP MM Fabric Number] ,
                'Products From BOM'[Current SAP MM Part Number] ,
                'Products From BOM'[Old SAP MM Part Number]) ,
            "@Totals" ,
        [@Totals] ) ,
    2 )
Hello @Krays23,
The solution provided onto this thread is based on the initial question which was posted.
For the new scenario’s, please create a new thread as per the Forum guidelines.
Harsh
