Calculated column not updating when published to workspace
We have a calculated column that updates budget value for month YTD based on prorata number of days in month. Thi smeasure is working fine in pbix file but when published to workspace and app it fails to update. IF you download pbix file from app, it shows correct amount.
Hi @KenC,
What is the storage mode of dataset and what type of data sources does it include?
Can you translate the logic for this CC to Power Query?
Maybe reviewing this article will help you resolve the issue.
Hi Melissa
Lineage view is as follows:
Everything seems to update except calulated columns from Excel workbook in Sharepoint which are budgets. Note the content of this file is static, the calculated columns prorata the budgets each day to get a MonthTD and YTD figure.
Ok, getting closer now. OneDrive Refresh isn’t happening.
I don’t have Admin access to thse settings in the dataset. Is it possible the file id has changed so it is not bringing in new data and refreshing calculated columns. Even when I refresh visuals on page it doesn’t update.
Hi @KenC! We noticed that your inquiry was left unsolved for quite some time now.
