Hey guys,
Maybe someone here can help me with my dilemma… I can’t seem to figure out how I can get the AverageListPrice for each row using the Qty and ListPriceExtended columns. I did the measure below for the AverageListPrice, but the SUM statements are taking the sum of the full table and not just the sum of the SKU:
AverageListPrice = SUM(MarkDownRaw[ListPriceExtended]) / SUM(MarkDownRaw[Qty])
Here is the table that I’m working on:
I also included a sample table with breakdown of a SKU:
Thanks in advance!
Try using the DIVIDE function your measure, and not the /. This would definitely be a best practice that Sam would suggest. Also you more than likely need SUMX and not SUM. In future posts it also helps tremendously if you post your PBIX file, or a sample file if data is sensitive. Try the following measure:
AverageListPrice = DIVIDE(SUMX(MarkDownRaw, MarkDownRaw[ListPriceExtended]) , SUMX(MarkDownRaw, MarkDownRaw[Qty]) ) )
Yes as per Jarrett mentions above here, it looks like all you need is better function selection.
Definitely use DIVIDE instead of /
Also a stronger understanding of SUMX and iterating function is required here.
I would run through the Mastering DAX Calculations course as soon as you can. There is a whole section on this material and these techniques
See below.
Check out these specific tutorials as well.
http://portal.enterprisedna.co/courses/mastering-dax-calculations/lectures/2000592
http://portal.enterprisedna.co/courses/mastering-dax-calculations/lectures/2399489
