Hi
I’d like to segment my customers based on their predicted sales in order to use this as a cohort
How do I get the segment into a calculated column in the Customer table
Customer Attrition UL - Upload.pbix (789.8 KB)
Thanks for any help
Hi
Thanks for any help
Thanks for posting your query can you tell more what actually you want and if possible a expected output will do a grt help.
Thanks,
Anurag
Hi
I’d like their predicted banding to be add to the customer table
The groupings are based on monthly invoice values
So based on the predicted mth sales column I’d like the customers original segmentation to be added on the customer table in a new column
The two shown would be in the >8000 group
You need to create the below calculated column in your customer table:
Sales banding Id =
VAR cus=Customers[Customer]
VAR su=Customers[Predicted Mth Sales]
VAr _id=MAXX(FILTER(‘Sales Banding’,‘Sales Banding’[Max]>su && ‘Sales Banding’[Min]<=su),‘Sales Banding’[SortID])
return
_id
And you can connect that id column to your banding table to use it further in your report.
I hope this solve your problem.
Attaching the pbix for your reference:
Customer Attrition UL - Upload.pbix (790.5 KB)
Thank you - with a little tweak for the column to return it works a treat.
