Each row is a survey response from the date it was taken.
The only way I know which is the pre survey and which is the post survey is by the date taken, so what I’m looking for is a column that tells me if the survey was completed before of after an assigned date.
I’m looking for the answers to be in a calculated column here not a measure.
Hi there,
Using the measure above, would it be possible to limit the MAXX filter to only past dates/that happened before “today”?
For example, imagine if there were some forecast survey dates in there for some time in the future, but I just wanted my MAXX date to pick up the last instance that has actually occurred.
Can I somehow get the measure to ignore all instances with a date later than today’s date?
Please create a new post with your question, your work in progress .pbix file and a mock up of the solution you are searching for. This post was already marked with a solution
