Calculate next bdays
Hi Guys,
Birthday.xlsx (17.4 KB)
I am trying to calculate the number of days till the next b-day in the query editor.
I run into an issue if the person has the bday on 29/02.
Could you please help me to resolve the issue?
Please find the attached file.
Thank you,
Mateusz
Hi @Matty. As this is a forum for Power BI issues, please upload your work-in-progress PBIX file plus a marked-up screenshot and/or Excel mockup of the visual of interest showing your desired outcome.
Hi @Matty, as mentioned by @Greg above, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
@Greg Apologies,
Bday.pbix (18.9 KB) Birthday.xlsx (127.4 KB)
Please find the corrected files.
As I mentioned I run into an issue while calculating the next coming bday for the person. The error occurs when someone is born 29/02.
I used below code to calcualte next bday.
let
Source = Excel.Workbook(File.Contents(“C:\Users\MWojnach\Documents\Project\Birthday.xlsx”), null, true),
Table1_Table = Source{[Item=“Table1”,Kind=“Table”]}[Data],
#“Changed Type” = Table.TransformColumnTypes(Table1_Table,{{“Dob”, type date}}),
#“Added Custom Column” = Table.AddColumn(#“Changed Type”, “Custom”, each Text.Combine({Date.ToText([Dob], “dd”), “-”, Date.ToText([Dob], “MMM”)}), type text),
#“Changed Type1” = Table.TransformColumnTypes(#“Added Custom Column”,{{“Custom”, type date}}),
#“Added Custom” = Table.AddColumn(#“Changed Type1”, “Today”, each DateTime.Date(DateTime.LocalNow())),
#“Added Custom1” = Table.AddColumn(#“Added Custom”, “Diff”, each [Custom]-[Today]),
#“Changed Type2” = Table.TransformColumnTypes(#“Added Custom1”,{{“Diff”, Int64.Type}, {“Today”, type date}}),
#“Added Custom2” = Table.AddColumn(#“Changed Type2”, “NextBday”, each if [Diff] < 0 then Date.AddYears([Custom],1) else [Custom]),
#“Added Custom3” = Table.AddColumn(#“Added Custom2”, “NextB-day days”, each [NextBday]-[Today]),
#“Changed Type3” = Table.TransformColumnTypes(#“Added Custom3”,{{“NextB-day days”, Int64.Type}})
in
#“Changed Type3”
The errors occur in applied steps (step Changed Type1) I understand why it happened as 29/02/2021 doesn’t exist.
I will appreciate it if you could guide me/ give me a hint on how could I resolve this error.
I thought to add additional logic such as if the year is ending 1 then add 3, if 2 then add 2 but then we would run into an issue if the year is ending 0 then you would add 4 or would add 0.
2020, 2024, 2028, 2032,2036,2040
Thank you,
Mateusz
Hi @Matty,
Give something like this a go, just paste the code in a New Blank Query. You didn’t state how you wanted to handle birthdays on the 29th so I moved them a day forward.
let
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("TcfJCQAgDATAXvJ2YRPP1BLSfxuKfoT5TIRQcXiTLCHmoIH8staNdqhh6ksFB0a/4UmFu2Ru", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Dob = _t]),
    ChType = Table.TransformColumnTypes(Source,{{"Dob", type date}}),
    NextBday = Table.AddColumn(ChType, "Next Bday", each
        let Today = Date.From(DateTime.FixedLocalNow()),
            nDate = try #date( Date.Year( Today ), Date.Month([Dob]), Date.Day([Dob])) otherwise #date( Date.Year( Today ), 3, 1)
        in
        if nDate < Today
        then try #date( Date.Year( Today )+1, Date.Month([Dob]), Date.Day([Dob])) otherwise #date( Date.Year( Today )+1, 3, 1)
        else nDate
in
    NextBday
I hope this is helpful
@Melissa
Thank you, I give it a go and I changed only one thing:
let
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText(“TcfJCQAgDATAXvJ2YRPP1BLSfxuKfoT5TIRQcXiTLCHmoIH8staNdqhh6ksFB0a/4UmFu2Ru”, BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Dob = _t]),
ChType = Table.TransformColumnTypes(Source,{{“Dob”, type date}}),
NextBday = Table.AddColumn(ChType, “Next Bday”, each let Today = Date.From(DateTime.FixedLocalNow()),
nDate = try #date( Date.Year( Today ), Date.Month([Dob]), Date.Day([Dob])) otherwise #date( Date.Year( Today )+3, 2, 29)
in
if nDate < Today
else nDate)
in
NextBday
I changed to 2024 as I would like to find out when the next bday will fall :slight_smile:
Saying that I could slightly change my m-code if the date and month = 29/02 then add the year 2024 otherwise apply the rest of logic :slight_smile:
Thank you,
Matty
@Melissa
in
if nDate < Today
else nDate
in
NextBday
Could you please suggest where I could read on to have a better understanding of the functions in the m-code. (with some examples)
Correct me If I am wrong but
Function1 =Today = Date.From(DateTime.FixedLocalNow())
Function2 = nDate = try #date( Date.Year( Today ), Date.Month([Dob]), Date.Day([Dob])) otherwise #date( Date.Year( Today ), 3, 1)
but then Function2 is diveded to “try” and “otherwise”?
I am trying to understand the part with “try” and “otherwise”
Am I right to say “try” is the first pattern in function 2 that should work and if the error will occur in the function pattern 1 then the formula will go to the 2nd stage which is “otherwise”?
Thank you!
Matty
Hi @Matty,
I’ve created a post on that, you can find it here:
Thank you @Melissa!
