Hello all,
in Topic Calculate days of open project until end of month you helped me to develop the correct formula for an analysis. Thx so far to @ankit for the final solution.
# Overdue closed in days 2 =
var MaxDate = maxx(VALUES(Dates[Date]),Dates[Date])
var MaxDateMonth = month(MaxDate)
return
CALCULATE( SUMX(
SUMMARIZE('crm Tätigkeit_BI', 'crm Tätigkeit_BI'[created], 'crm Tätigkeit_BI'[performend], 'crm Tätigkeit_BI'[closed], "End of Month", ENDOFMONTH(Dates[Date]),
"DaysBetween",
IF(
MONTH('crm Tätigkeit_BI'[performend]) = MaxDateMonth,
DATEDIFF('crm Tätigkeit_BI'[created], 'crm Tätigkeit_BI'[performend], DAY),
IF(
MONTH('crm Tätigkeit_BI'[closed]) = MaxDateMonth,
DATEDIFF('crm Tätigkeit_BI'[created], 'crm Tätigkeit_BI'[closed], DAY),
IF(
MONTH('crm Tätigkeit_BI'[created]) = MaxDateMonth,
DATEDIFF('crm Tätigkeit_BI'[created], MaxDate, DAY),
BLANK()
), [DaysBetween]),ALL(DATES))
Unfortunately, I only noticed after marking task Calculate days of open project until end of month as closed, that the total is calculated wrong.
I tried to solve this by another Sumx for the Total, but somehow I didn’t get it work.
May someone of you can help me with a correct calculating solution?
Thanks in advance
Danilo
FSM_Master_test_v1.0 - w Connection.pbix (5.5 MB)
Harsh
October 21, 2021, 9:54am
2
Hello @d.mesch ,
Firstly, rather than using a flat file you’ll be required to create the dimension tables. In this case, I’ve created 2 dimension tables - “Typ Table ” and “Typ 2 Table ”. And created a relationship with the “crm Tätigkeit_BI Table ”. Below is the screenshot of the new relationship status provided for the reference -
Now, to fix the totals below is the measure alongwith the screenshot of the final results provided for the reference -
Correct Totals =
VAR _Cross_Joins =
CROSSJOIN(
VALUES( 'Typ Table'[Typ] ) ,
VALUES( 'Typ 2 Table'[Typ2] ) ,
VALUES( Dates[Month Name] ) )
VAR _Virtual_Table =
ADDCOLUMNS(
_Cross_Joins ,
"@Totals" ,
[# Overdue closed in days] )
VAR _Remove_Blanks =
FILTER(
_Virtual_Table ,
NOT ISBLANK( [@Totals] ) )
VAR _Results =
SUMX(
_Remove_Blanks ,
[@Totals] )
_Results
I’m also attaching the working of the Excel as well as PBIX file for the reference purposes.
Thanks and Warm Regards,
Harsh
Typ - Dimension Table - Harsh.xlsx (1.3 MB)
FSM_Master_test_v1.0 - w Connection - Harsh.pbix (5.5 MB)
d.mesch
October 22, 2021, 10:07am
3
Thanks @Harsh for your quick solution.
I hope that one day I can return it to you.
Danilo
Harsh
October 22, 2021, 12:12pm
4
Hello @d.mesch ,
You’re Welcome.
I’m glad that I was able to assist you and you found it helpful.
And thank you so much for your kind words.
Harsh
