Calculate Clients in Date Range
I want to count all Clients that have been seen during a selected date range (via a slicer). The count is to only include Clients in the Individuals Table that also have an ID in the WB-Case Table and were existing or new clients during that time, must only include:
  • Clients that have a Date Entered before or during the selected Date Range AND
  • Clients that have an Exit Date either during or after the selected Date AND
  • Include Clients that have a blank Exit Date (not exited yet)
Individuals (table):
  • Client (column)
WB-Case (table):
  • ID (column)
  • Date Entered (column)
  • Exit Date (column)
DateTable (table):
  • Date (column)
Hi @BrittKing - Please share a sample PBIX file to look into this.
Ankit J
You can try something like this:
Clients in Date Range =
VAR StartDate = MIN(DateTable[Date])
VAR EndDate = MAX(DateTable[Date])
    DISTINCTCOUNT(Individuals[Client]),
    FILTER(
        'WB-Case',
        'WB-Case'[Date Entered] <= EndDate &&
            ISBLANK('WB-Case'[Exit Date]) ||
            'WB-Case'[Exit Date] >= StartDate
This counts clients who entered on or before the selected date range, and exited during or after it — or haven’t exited yet.
Make sure relationships are set correctly between tables.
Thank you, it is including those with or without an exit date appropriately however it doesn’t appear to be including those that were entered prior to the selected date range.
