Calculate Average of Average
Good day Team
I need some guidance on calculating the average of a calculated average
Example example: AVG # Calls is what i am after
Hello @neilonbooysen,
You can do this with the AVERAGEX function. I am assuming you want the average across your market column in the table…
AVERAGEX( VALUES( [Market] ), [Average] )
Type out the AVERAGEX function, then use the VALUES function and place your market column there. (This creates a virtual table of your list of markets). Then put in the Measure you created called Average.
Let me know if this works.
Thanks,
Randall
perfect Randall, i had to amend a few things on base calculation but you guided me so thanks alot
