Calculate against date in dax
Hi All,
I need help with the below case. what i want to achieve is, anybody who has subscribe before November then calculate the fees from Nov to the current month or any members who registered after November, calculate the subscription cost by from subscription date.
NB: The Nov date is hard coded and i have attached an excel file …column E has the calculation but need to be based on the date.
My table columns:
Subscription date, subscription amount, first name and last name.
THANKS IN ADVANCE
IF
subscription_date < 1/11/2022
THEN
one_off_amount = member_subscription.subscription_cost * no. of months from November 2022 to the current month (eg. Nov – Dec = 2 months )
ELSEIF
Subscription_date >=1/11/2022
THEN
one_off_amount = member_subscription.subscription_cost * no. of months from month(subscription_date) to the current month (eg. Nov – Dec = 2 months)
test_file.xlsx (9.4 KB)
Hello @alora101,
In order to achieve the results based on the scenario that you’ve mentioned. Below is the DAX measure alongwith the screenshot of the final results provided -
One of Payment =
VAR _Pre_Defined_Subscription_Date_Parameter =
DATE( 2022 , 11 , 01 )
VAR _Todays_Date =
TODAY()
VAR _Subscription_Purchased_Before_Pre_Defined_Date =
ADDCOLUMNS(
    FILTER( Data ,
        Data[Subscription StartDate] < _Pre_Defined_Subscription_Date_Parameter ) ,
    "@One_Of_Payment" ,
    ( DATEDIFF( _Pre_Defined_Subscription_Date_Parameter , _Todays_Date , MONTH ) + 1 ) * Data[Subscription Cost] )
VAR _Subscription_Purchased_After_Pre_Defined_Date =
ADDCOLUMNS(
    FILTER( Data ,
        Data[Subscription StartDate] >= _Pre_Defined_Subscription_Date_Parameter ) ,
    "@One_Of_Payment" ,
    ( DATEDIFF( Data[Subscription StartDate] , _Todays_Date , MONTH ) + 1 ) * Data[Subscription Cost] )
VAR _Results =
SUMX(
    UNION(
        _Subscription_Purchased_Before_Pre_Defined_Date ,
        _Subscription_Purchased_After_Pre_Defined_Date ) ,
    [@One_Of_Payment] )
_Results
Thanks and Warm Regards,
Harsh
One of Subscription Payment - Harsh.pbix (81.9 KB)
Thanks very much. Exactly what i wanted.
Much appreciated
Thanks a million
Hello @alora101,
You’re Welcome!
Harsh
