Business Analytics Week Dataset 14-16/12
Hello,
Is there a practice dataset/resource set for the event in subject ?
Best
Rafal
To check the resources for this event, check out - Business Analytic Week - Dec 2020. For any questions on the content, please start a new topic within the forum. You may check this how-to guide for reference - How To Use The Enterprise DNA Support Forum
I checked that out - can’t really find it though
Hi @Rafal_j the resources are in the Replay Page. You can refer to this REPLAY LINK.
Hi @Rafal_J, we’ve noticed that no response has been received from you since the 16th of December. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
Hi @Rafa_J, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
