I am trying to work as a Business Analyst .
But I need if someone can help me with the path of learning because I have 1 year of understanding as Data Analyst.
Earlier,I worked as a Operations Specialist so I need if someone can guide to go through step by step in Enterprise DNA courses with the basics and then can have good presentation skills.
Secondly,fill the gap between Operations Specialist ----> Data Analyst β>Business Analyst journey.
It will be very helpful for me if someone guides here.
Hi there
Did you check out all the learning paths that is built in the learning center? Each learning path state the courses involved under each learning paths.
Every company has a different meaning for Business Analyst. Maybe do some research on job requirements for business analyst job titles on the internet. From my experience, Business Analyst job titles does a lot of business requirement gathering and putting that in a report to give to IT area.
welcome to Enteprise DNA. There are lots of materials and sessions to explore.
I agree with Keith - in different companies β different Business Analyst role.
Data Analyst part is covered with Data Analyst Learning path - in short see what you need to improve from Data Analytics and Power BI part:
Power BI SuperUser β great as a base foundation (to cover all pillars)
β’ Data Transformation and Modelling (specially data transformation examples and advanced techniques + in designing advanced data models you can find out best practices)
β’ Mastering DAX
etc.
For Business Analyst part
β’ Exam PL-300: Microsoft Power BI Data Analyst β Discover data analysis (as Intro of different data roles)
β’ Dashboarding & Data visualization intense (itβs not just about visualization and dashboarding but also you can see different analytics techniques, styles a and find out different DAX patterns and ideas how to use PowerBI)
β’ Data Storytelling And User-Centered Design In Power BI (great course from Alex Badiu -how to share your knowledge and story with data and sharpen your presentation skills)
There are lots and lots of trainings (even SQL part is covered) - if you look for some particular pattern or scenario maybe you can find it at:
β’ Learning Center β DAX Formula Patterns (also very useful to see different analytic techniques and practical patterns)
β’ Learning Center - >Scenario Analysis Deep Dive
β’ Analyst Hub - community part has also patterns repository
β’ Forum (search or if you could not find post new one)
β’ others
From Resource Center you can find different showcases (some from challenges) from which you can learn a lot - more you can find at: https://app.enterprisedna.co/app/showcase
If you looking for improving presentation skills - I recommend Reporting & Data Visualization Summit - there are lots of great sessions with practical examples and ideas.
Donβt miss Industry Analytics and Application Summit in November β more details you can find at:
Lots and lots of materials to explore and learn from.
