Not sure if this is the correct category to ask this query but here goes.
I have a BI report that analyses 3.5 million rows of sales data. To extract the sales data from our database I have to run about 8 exports and then combine them using Power Query append queries. (The database export query hangs if I try to export all sales records.)
Our database does have a report that outputs only modified or new sales records. If I run this report daily, modified data would only be a few thousand records. A data file this small I can import into Power Query via a get API.
Is it possible to have the sales table sitting somewhere and when the new/modified sales records are loaded daily, data in the sales table is either replaced if the Sale ID already exists or added to the data table if its a new sale?
I don’t think I have the ability to incrementally refresh.
I can however each day run a report that shows the sales records modified yesterday:
My thinking was if I had a static table, each day it could be updated with the daily modified data report.
The logic would be if the Sale ID does not exist, add the sale to the static table. If the Sale ID does exist, overwrite the sale with the modified data.
Hi @KieftyKids - Could be possible using Merge in Power Query and using Full outer join but again this will need to load all data in power query and perform the join which will be highly memory sensitive and time consuming and may fail also.
Will suggest to consider some other tools like Azure Data Factory (ADF) or Informatica that are made for these purpose.
Due to inactivity, a response on this post has been tagged as “Solution”.
