Is it possible to build a financial forecast in PowerBi by combining the ‘actual data’ for say 5 months and use the ‘budget data’ for the remaining ‘7 months’?’
Hi @grant, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
When posting a topic with formula make sure that it is correctly formatted to preformated text </>.
Include demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
Hi @grant, we’ve noticed that no response has been received from you since the 9th of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
Hi @grant, you may also want to check this video where Sam talked about budgeting. You might get additional tips here.
