Break ranking ties in a calculated column!
Hello team,
I want to break ties in a calculated column but I am not sure how it will work. I have created a ranking column and when “MW Loss” is same, I get multiple values. In case of same “MW Values”, I want to break ties by the Block. Is it possible. Snapshot and PBI file is attached below:
PBI ranking test !!.pbix (23.2 KB)
Regards,
Naila
Hi @Naila
You could try the new RANK function, which works similar to windows functions in SQL if you’re familiar with those:
Ranking 2 =
RANK(
    DENSE,
    ORDERBY( Data[MW Loss], DESC, Data[Block], DESC)
Changing the last DESC to ASC will change which order it uses the Block column as required.
PBI ranking test !!.pbix (23.7 KB)
Hello @Naila
Thank you
Hi @jamie.bryan ,
Thank you for providing the solution. This is the exact solution I was looking for.
Thanks again !!
Regards,
Naila
