Hallo
attache a PBIX
all seems to work but I can get the cumul of the bonus to work
I use the window()
any help is very appreciated
kind regard
roger
test leveranciers bonus.pbix (169.9 KB)
Hallo
attache a PBIX
I use the window()
kind regard
roger
Is there anyone who can help me with this problem of the running total of the cumulative bonus ?
Dear @Roger ,
Answer:
A solution is using the default dates from the Datumtabel, instead of month-nr, whereby it becomes possible to use the standard YTD and date-add functions.
For the correct context for the standard time-intelligence measure-formulas, Datumtabel.Date has to be used (in the rows of the table), which could be aggregated to months.
However I am still struggling to present the totals for all the Leveranciers and total of the monthly bonus…
PBIX attached:
test leveranciers bonus (2).pbix (172.7 KB)
Cumulative YTD-Bonus is calculated on cumulative YTD sales x bonus %, monthly bonus is derived as a result of cumulative YTD bonus -/- cumulative YTD bonus of previous month.
Measures: (all can be found in the measure group “Add. measures”)
Cum YTD Sales II = CALCULATE(TOTALYTD([Gross Sales],DATUMTABEL[Date]))
Prev. Cum YTD Bonus II = if(MAX(DATUMTABEL[Date].[MonthNo]) = 1, BLANK(),
CALCULATE([Cum. YTD Bonus II],DATEADD(DATUMTABEL[Date],-1,MONTH)))
Table with cumulative bonus: ( totals per Leverancier and for all Leveranciers must still be worked out)
I hope it helps you further,
Kind regards,
Jan van der Wind
Jan
thank you very much for the solution and the explanation how to get there
kind regards
Roger
Goedenavond @Roger,
To let your Bonus-measure work for multiple Leveranciers, it should be :
var LEVerancier = SELECTEDVALUE(LEVERANCIERS[ID])
“Selectedvalue” instead of “Values”
Kind regards, Jan van der Wind
