Hello @christina.weber,
You cannot remove blanks using the Filter Pane option without having a direct effect over another visual since those 3 fields are coming from the same Date table and that too, they’re of different magnitudes i.e., Last 30 Days, Last 6 Months and Last 8 Weeks.
Therefore, in order to achieve the results, you’ll be required to write 3 different measures rather than creating 3 different calculated columns in the Date table. Below are the measures provided -
Salary L30D =
VAR _Max_Date =
CALCULATE( MAX( data[Date] ) ,
ALL( data ) )
VAR _Last_30th_Day_Date =
DATE(
YEAR( _Max_Date ) ,
MONTH( _Max_Date ) ,
DAY( _Max_Date ) - 29 )
VAR _Results =
CALCULATE( SUM( data[salary] ) ,
FILTER( ALL( data[Date] ) ,
data[Date] >= _Last_30th_Day_Date &&
data[Date] <= _Max_Date ) )
_Results
Salary L6M =
VAR _Max_Date =
ALL( data ) )
VAR _Last_6th_Month_Date =
DATE(
YEAR( _Max_Date ) ,
DAY( _Max_Date ) - 183 )
VAR _Results =
data[Date] >= _Last_6th_Month_Date &&
_Results
Salary L8W =
VAR _Max_Date =
ALL( data ) )
VAR _Last_8th_Week_Date =
DATE(
YEAR( _Max_Date ) ,
DAY( _Max_Date ) - 56 )
VAR _Results =
data[Date] >= _Last_8th_Week_Date &&
_Results
Now, create two field parameters. One field parameters will contain these 3 measures and the other one will contain the actual fields/columns i.e., for Last 30 Days, the field will be Dates. For Last 6 Months, it’ll be Month & Year and for Last 8 Weeks, the field will be Week & Year.
So, now against those 3 measures, you’ve 3 fields as well. And hence, create a “One-to-One” relationship between the two field parameters. This is how it’ll look like -
Finally, place the field “Fields In Parameter” onto the X-axis of the chart and on the Y-axis place the “Variables”. So, now when you switch between the parameters, you’ll see the results as expected and not any blanks. Below are the screenshot provided -
Thanks and Warm Regards,
Harsh
Sample_Blank Parameter - Harsh.pbix (136.6 KB)
