To clarify, it allows for very limited connections like remote desktop via VPN .
I can’t use it to sign in to Power BI Desktop for example or to download updates, download visuals, go to any websites, etc.
I was wondering if not being able to sign in made a difference. Not sure what else it could be… When I sign out of my machine I am still able to see the beta connections.
Keeping the internet issue aside the options you are getting in the remote machine are much less than what I have on my version of PBID. Is there a possibility that it is an older version ( do a re-check ) or maybe the report server version, I am not sure but worth checking.
I might close this out because I think it has something to do with windows permissions. The last thing I did was verify that TIBCO.pqx was installed on both machines and it was.
Hi @DeanJ, did the response provided by @AntrikshSharma help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
