Hi everyone,
I’m working with a data model where the majority of my data is provided via a Post_Period field in the format YYYYMM. This Post_Period represents all activity posted during that specific period, but it doesn’t directly correspond to an actual date.
To better align with time-based dimensions and facilitate time intelligence calculations, I’m considering adding a calculated column in each of my fact tables that sets the date to the last day of the month corresponding to the Post_Period. For example, if the Post_Period is 202408, the calculated date would be August 31, 2024.
Additionally, I’m struggling with creating visuals that compare Current FY vs. Prior FY (across multiple years) to date. The challenge arises because the current month often has no data available, as it’s all reported for the previous month. This makes it difficult to create accurate and meaningful year-over-year comparisons, especially when trying to visualize trends over time.
Before I proceed with this approach, I wanted to get your thoughts:
- Is adding a calculated column for the last day of the month a common practice for handling period-based data in Power BI?
- How do you manage the challenge of comparing year-to-date visuals when the current month doesn’t have data yet?
- Are there any potential pitfalls or better alternatives I should consider?
- How might this impact performance or usability in larger models?
Any advice or experiences you can share would be greatly appreciated!
Thanks in advance for your help!
