Best hardware for BI Development
I am having more and more problems developing BI projects on my Macbook Pro. I have 16g ram with a 2.9 GHz Quad-Core Intel Core i7 processor. Using Parallels with 8g memory and 6 processors allocated to Windows. Daily run into memory and or CPU maxed out.
I don’t want to give up my Retina display, but definitely need more horsepower. Should I change to dedicated Windows machine?
@Irv,
I would. I’m running a hex core i9 with 32 gigs of RAM and have never maxed out either the memory or the CPU even on my largest models.
Hi @Irv. Until recently, I was using an off-the-shelf Windows 10 i5 with 8 GB of RAM and, although lagging occasionally, very rarely ran into CPU or memory locks. I’d do it.
I have had similar issues. Installing boot camp is an option, and for me, has increased performance.
Hi @Irv, did the response provided by the users and experts help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @Irv, we’ve noticed that no response has been received from you since the 10th of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @Irv, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
