Has anyone done any ChatGPT integration using Azure OpenAI service in a private tenant? If so, did you write your own chatbot or did you Git clone from some popular repositories? if so, which one? I’m using Mckay Wrigley’s chatbot ui for now but there isn’t very much documentation in it. Ultimately, I need the Endpoint url and the API key but the Azure architecture can quickly turn complex and costly with security controls, notifications, monitoring… any good courses here relating to the integration?
