Thanks for posting your question @adam. To receive a resolution in a timely manner please make sure that you provide all the necessary details on this thread. Here is a potential list of additional information to include in this thread: demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
Hi @adam we’ve noticed that no response has been received from you since the 30th of September. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
