Hello,
I am trying to calculate the average number of employees in a month. I was able to have it calculated at any point in time previously.
However, how can I try to do an average on this?
AvgEnrolled.pbix (138.6 KB)
Hello,
Hello @supergallagher25 ,
please see if attached fulfills your needs.
Cheers,
Seb
Thank you for taking the time to answer this @Slipper
Hi @supergallagher25 , did the response provided above help you solve your query?
Hi @supergallagher25 we’ve noticed that no response has been received from you since Oct 8.
Thank you so much for pointing it out.
Yep, tagged the wrong person.
By the way, thank you so much for the PBIX solution you sent above
Hi @supergallagher25, due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, please create a new thread.
Thank you this worked.
My apologies for the late response, I had an issue trying to log back in.
