Average & Grouping
I was looking for similar topic but get no clear solution to the challange I faced.
The scenario fact table #1 comprises count of users with access to the intranet (available for different locations of the Company, changing on a daily basis) like here:
The scenario fact table #2 comprises daily IDs of users logging in to the intranet like here (of course dummy data in excel; the actual facttables have many sensitive data as well as powerbi model):
What I have already did is to compute DAU (Daily Active Users)
ActiveUsers =
    COUNTROWS(
        DISTINCT(Logs_Table[User ID])
and average for last x days.
DAU (average L7Days) =
VAR _Number_of_Days = 7
VAR _MaxDate = SELECTEDVALUE(Logs_Table[User ID])
VAR _Period = DATESINPERIOD(Calendar[Date],_MaxDate, -_Number_of_Days, DAY)
VAR _Result = CALCULATE (
                AVERAGEX (
                    VALUES (Calendar[Date]),
                        [ActiveUsers]
                _Period
VAR FirstDateInPeriod = MINX (_Period, Calendar[Date] )
VAR LastDateWithLogging= MAX ( Logs_Table[Date])
 IF(FirstDateInPeriod <= LastDateWithLogging, _Result,"-")
MAU (Mounthly Active Users) I got thanks to visualisation / filter context which is not probably the best practice but I made it.
So what are the challanges
  • compute MAU and DAU/MAU ratio on a daily basis.
  • compute the potential of users = total count of users on a monthly basis like here:
I believe the solution is about:
You will have to create multiple measures for each level of granularity:
Daily:
Daily Active Users (DAU) = CALCULATE(DISTINCTCOUNT(Logs_Table[User ID]),DISTINCT(DatesTable[Date]))
Daily Potential = SUM(Users_With_Access[Credits])
Daily Utilization = DIVIDE([DAU],[Daily Potential])
Monthly:
Monthly Active User (MAU) = CALCULATE(DISTINCTCOUNT(Logs_Table[User ID]),DISTINCT(DatesTable[MM_RR]))
Monthly Average Potential = AVERAGEX(Users_With_Access, [Daily Potential])
Monthly Utilization = DIVIDE([MAU],[Monthly Average Potential])
Yearly:
Yearly Active Users (YAU) = CALCULATE(DISTINCTCOUNT(Logs_Table[User ID]),DISTINCT(DatesTable[Year]))
Yearly Utilization = DIVIDE([YAU],[Monthly Average Potential])
For Sum of Averages, you can refer to the below blog post:
DAX Calculations Power BI: Total Of Average Results | Enterprise DNA
I have created a sample solution for your quick reference.
DAU and MAU dummy data for EDNA_Solution.pbix (59.1 KB)
@pranamg Much appreciate your great effort. I need to go through your solution and let you know if everuthing is working properly. At the moment I see an issue that Monthly Potential (as well as yearly) is for sure not 22,9 but rather 114,3. So the utilization is also not 74% but rather ~10%.
But as I said I will go through your proposal and apply it to my real case data and let you know .
Best
Aldek
Thanks @Aldek_U . Yes, you are right. The totals will not display the sum as the DAX functions will only display Averages. I did not attempt Sum of Averages DAX function for totals. For that, you might have to refer to the blog post ->. DAX Calculations Power BI: Total Of Average Results | Enterprise DNA .
Hi @Aldek_U, we’ve noticed that no response has been received from you since a few days ago.
We just want to check if you still need further help with this post?
Hi @Aldek_U, due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, you can create a new thread.
