Hey Guys,
I’m wondering if there’s a way I can automate an API call. I’m currently retrieving call data files via API which is being made through Postman. Is there any way I can automate this process of receiving the data without having to log on to Postman to make the calls everyday? The user wants the ability to check the agent calls every day.
You can also consider using Visual Studio Code or Power Automate for making automated API Calls.
Hi @eobiki10, did the response provided by @Melissa and @pranamg help in solving your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
I’ll be responding soon on the method that worked for me. Thanks
Hi @eobiki10, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
